What can I do if Brim returns limited, and irrelevant response
Just starting using Brim. And when I put my prompt into the platform the response is limited and often irrelevant. Is there anything I can do to get a better response?
Hi Oscar - Great question.
There are quite a few things you can do but to advise properly it would be great to find out more about your goals response. So what is your goal response for example: it is very details or concise?
Thanks.
Generally I want to write concisely. But that is not really the issue. The issue is that the agent is normally writing about something that I did not expect.
Okay I understand. This could be an issue with how you a prompting the agent. But i cannot be certain without seeing the thread.
Would a call with me or @almira be useful and you can show us the issue you are having and we can advise and how you can prevent them for happening.
