Using two LLMs together
A great tip a colleague recently shared with me is to use two AIs together. For example, you can write your prompt in ChatGPT and get a response, then ask Claude to review it and suggest improvements based on your criteria. And rinse a repeat, this get me much better outputs.
Has anyone else tried this approach?
Hi @AHussein - Great to see your first post being so useful!
This is a great tip to do when using AI and I use this all the time. To add to it I would recommend defining the criteria yourself and giving that to the AI beforehand.
