The canvas lock after deleting one character
While editing a document on your Canvas window (On the right) when I delete one character the whole things freezes.
But I do like the highlight and ask and agent ability.
@Samantha_Lee
I’m tagging my colleage @almira who is going to take a look at this for you :slight_smile:
Kenny
Good spot, thanks for flagging that!
That freeze when deleting a character is definitely not how it’s meant to work, it’s likely a rendering bug we’ve seen pop up occasionally in the Canvas. For now, a quick refresh usually fixes it temporarily.
We’re actively working on improvements to Canvas, including stability fixes like this one, so it should be much smoother very soon!
Okay great to hear. Thanks
