No matter what agent I am on the prompt which are suggested are the same. I’m guessing this is unintentional
Strange this should not be happening and you have found a bug, thank you. Which agents is this happening on?
It all the ones I have access to so the Brim and Data agent.
Okay thank you. In this section their should be prompts which are agent specific to help you understand the questions you can ask.
Is this what you would expect?
