I’m new to using AI. Is there anything I can do to make sure I get the best response possible sometimes the response is disjointed and does not really write like me.
Welcome @RebeccaC !
One simple tip is to give the AI a bit of context upfront. For example, you can say things like “Write this in a friendly but professional tone” or “Make this sound like how I’d say it, clear and casual.” The more specific you are about what you want (tone, format, audience), the better the response will match.
If the AI doesn’t respond the way you expect it to, ask them to change certain parts of it since it learns best when you guide it.
We’re also actively improving how well agents adapt to your voice over time, so it’ll keep getting better the more you use it!
Thanks so much. This is super helpful
