Been using Brim recently and noticed that the Cross Thread context does work. But only sometimes.
For example it will sometimes remember how I want a document to be format, then other times completely forget.
hi @RebeccaC . Hope your having a good beginning to your week.
Thank you for pointing of this issue. Would be great to find out some more about the issue you are having.
Are you using the same agent across all the threads?
Hiya @Lukas
I use multiple different agents but the issue does not stem one the agent. For example I can be using the same agent and have the same issue over and over again and other times go onto a different agents and it is fine.
Any idea how this could be fixed?
