When using Brim I can see that while running my query my PC is very slow when I check the RAM usage is it very high for Brim.
Is there anyway to reduce this?
You should be able to reduce this. To help me understand what browser are you using?
Iām using Google Chrome
Okay. I would recommend using internet explorer as this uses less RAM.
How much RAM does your PC or laptop have available. You can view this by right clicking on the Task Bar ā Pressing Task Manager ā Going to the performance section
