The problem
One of the most common objections you will hear when AI comes up is simple and valid. “Is AI safe with our company data?”
This is rising concern with Shadow AI now widespread and teams using tools like ChatGPT, Gemini, or Claude without formal approval. For businesses handling sensitive or regulated data, this creates real risk.
Most public AI tools run on shared infrastructure and may temporarily store user inputs for quality control or model improvement. That is acceptable for casual use, but not for client data, financial records, or regulated information. In those cases, it can create issues around GDPR compliance, professional indemnity insurance, and confidentiality obligations.
The honest answer
If a client is using public AI tools with sensitive data, it is not safe enough.
That does not mean AI should be avoided. It means AI needs to be adopted deliberately, with the right controls in place.
This is something you can help your clients do moving from unsafe, informal use to controlled, defensible adoption.
How to advise clients safely: a practical framework
You can guide clients using four simple, actionable steps.
1. Treat AI like a new hire - AI should start with limited access and a clearly defined role. One task. One workflow. One outcome. Expand only once trust is earned.
2. Use the right environment - Recommend private or enterprise grade AI environments, like Brim, where data stays within approved infrastructure and is not used for public model training.
3. Ask vendors the right questions - Help clients with due diligence. Ask where data is stored, how long it is retained, who can access it, and whether it is used for training. If a vendor cannot answer clearly, that is a risk signal.
4. Keep humans in the loop - AI should support decisions, not make them alone. Human review is essential for finance, compliance, HR, and client facing workflows.
Why this matters
When AI is deployed with clear scope, private infrastructure, and human oversight, it often becomes safer than manual processes. Actions are logged, access is controlled, and behaviour is consistent.
If your clients are asking these questions, they are already on the right path.
We go deeper on this in our blog and podcast episode (Spotify | Apple), Is AI Safe for Your Company’s Data?
If you want to talk through how to handle these conversations with clients, feel free to reply here or message us directly.
