AI for image generation
Anyone know any good tools for AI image generation? I have tried Chat GPT but it was not very good
@Priya-AI - I would recommend Mid Journey- https://www.midjourney.com/
I second that. However you still have to be specific with your prompts.
It’s worth including details like:
  • Lens type (e.g. 85mm portrait, fisheye, macro)
  • Style (e.g. cyberpunk, oil painting, editorial, minimalist)
  • Lighting and shadows (e.g. soft lighting, high contrast, backlit)
  • Scene composition (e.g. close-up, wide shot, over-the-shoulder)
The more descriptive you are, the more control you’ll have over the final image.
If you’re not sure how to phrase it, ChatGPT can help generate a well-structured prompt — just describe what you’re imagining, and it’ll turn it into prompt-ready language.
Thanks @Alex-Mercer. I’m assuming you’ve looked into image generation in the past with AI. How have you found it?
Thank you, @Alex-Mercer . That was really helpful! My images are now looking much better.
Midjourney has really impressed me. I’m pleasantly surprised. Thanks, @Lukas!
For anyone interested, here are the top images generated using Midjourney: https://www.midjourney.com/explore?tab=top_week
