@almira On the side of Brim there are a few section that are not available yet; Search, Notification, Workflow, Knowledge and Marketplace.
What are these sections going to be used for?
Great question, Priya! Here’s a quick overview of what each section will be used for:
- Search: This will be a unified, company-wide search tool. You’ll be able to quickly find files you’ve uploaded, anything your AI agents have generated, and even search within threads and workflows so you’re never endlessly scrolling for the info you need.
- Notifications: Think of this as your agent inbox. You’ll get updates when a workflow needs your input (like approvals), when an agent is stuck, or when a task is ready for review. You’ll also get system alerts and mentions here.
- Workflows: This is your central hub for all saved and running workflows. You’ll be able to see how often they’ve been used, check the activity log, and jump into related threads. Soon, you’ll also be able to build your own workflows here.
- Knowledge: This is where all your files live – uploads, synced documents from your company drive, and anything generated by your AI agents. Everything is linked back to the workflow or thread it came from, so context is never lost.
- Marketplace: This will be the place to explore ready-made workflows, built by Brim and other users. You’ll be able to find templates that suit your use case and get started faster.
Hope that gives you a good sense of what’s coming. Feel free to tag me if you want to dive deeper into any of these!
Interesting.
Do you have a timelines for when these will be available?
